FLM hybrid bulks
Hey Guys,
I just put together the HB Diffs in the FLM Hybirds... Was I suppose to put a seal of some sort around the diff so the oil would not leak out? Or Im I just not tightening the diffs hard enough. I thought it was tight enough though. Did any you guys with these diffs put like a silicon seal before putting the two halfs together? THanks guys. Grant |
any ideas guys?
There's a orange o-ring that goes between the halfs. It should have come in the kit. Don't forget to put the small set screw in the hole where the pin goes in.
And you need a gasket between the ringear and the diffcase
| All times are GMT -4. The time now is 09:40 AM. |
