Hobao Hyper 7 Shock Dimensions?
Hi there,
is there any chance someone of you guys has the Hobao Hyper 7 shock dimensions? Eye to eye compressed, uncompressed, front, rear, and the outer diameter of the shock body. Those are the dimensions I would need to know. Thank's a lot, Jo |
When you know, let me know so I can add it to this page...
Rear:
diameter: 14.40mm compresses eye to eye: 85.5mm uncompressed eye to eye: 125.5mm front: diameter: 14.4mm compresses eye to eye: 70.50mm uncompressed eye to eye: 109.50mm |
Hey thank's a lot!
Are those 14,4mm the inner or outer diameter of the shock body? And could you give me the outer diameter of the springs as well? |
outside diameter of bodies...
od of springs is 19.85mm |
OK, thank you again!
But this means they won't fit on the SCRT10:whip: |
| All times are GMT -4. The time now is 06:01 PM. |
