all nomadio owners
I'm still building my 5b http://rc-monster.com/forum/showthread.php?t=27203 I got a nomadio react with it. Anything I should know?
I want to use channels 3 and 4 independently for switches. Reading the manual shows how to slave either 3 or 4 to 1 or 2, and how to operate 3 or 4 assigned to a function and A switch, but not how to assign 3 and 4 to seperate switches independent of one another. I want to use 3 to switch on and off NOS and 4 to switch on and off lights, but not at the same time. |
I have the Sensor, but really haven't taken the time to look at the channel mixing features. Not sure how close the menu and features are between the two radios, I'll take a look at it though.
Personally I'm thinking of getting rid of my Sensor since Nomadio doesn't provide service/support anymore. |
I never messed with the channel mixing. But I do like the react alot. Just nice to hook it up to your pc and mess/save your settings. The mini sr3500 rx work with it.
anyone know if it will bind with other RXs besides spek and nomadio??
I'm pretty sure those are the only two.
Now that they are no longer supporting the radios they should release their firmware for people to modify, turn it into an open source project. The problem is that when dealing with the radio signals you have to worry about FCC regulations, and they probably can't have people just messing around trying to get the firmware to work with Futaba, Airtronics receivers, etc. |
I believe losi recievers are spektrum compatible? That would make them also nomadio compatible... |
Yes, the Losi MRX-3000 receiver is a rebadged SR300.
If there aren't any issues with the FCC and 2.4GHz then maybe it would be possible to work on an open source firmware for Nomadio radios. The PC interface is already there, it would mainly be a matter of finding enough people who use Nomadio radios and would want to work on modifying the software. Probably not enough people interested. |
yeah, it's a dead company. Interest has been lost...
Nomadio
I have been searching far and wide for one of those alloy steering posts, know where to find one? Mine hasn't broke yet, but from what I've read it's only a matter of time.
Nomadio forum member.
I still use the Sensor and have Spektrum receivers in all my vehicles. I picked up a FlySky GT3 to play around with, mostly for the cheap receivers and to have a backup for my Sensor (because of the steering post issue)
I tried to contact the Hand Bros when the Nomadio forums were still active, but never got a response. I would buy one of the posts if I came across it, but not too interested in trying to get one custom machined. I have the latest software installed that still allows the use of Spektrum receivers. |
Possible???
I have the latest software installed that still allows the use of Spektrum receivers.[/QUOTE]
Is it possible to upload the software from the Sensor to your PC and then transfer it to a disc or thum drive? If so I would like to have a copy of the latest software/firmware for the Sensor on hand. I would be happy to send you a thumb drive to accomplish this task with return shipping paid for. I now have three Sensors. Then I could update my Sensors regardless of Nomadio's status right now. |
You can still download the Sensor and React software/firmware from Nomadio, including the registration patch.
| All times are GMT -4. The time now is 11:01 PM. |
