-   -   can a schulze 12.97 handle?? (https://www.rc-monster.com/forum/showthread.php?t=2762)
joostin420 04.06.2006 08:50 AM
can a schulze 12.97fe controller with Nemisis 12s handle a (2x) 2S - 7.4volt setup (14.8volts)? i know that 12cells is supposed to be the limit i think on the 12.97fe controller.
thanx,
justin
J Cates 04.06.2006 04:58 PM
That is defenitely pushin it, 12 cells would be 14.4 volts.
cspurlock 04.06.2006 05:09 PM
thanx,
justin
Justin,
I replied to you with an in-depth answer on the other forum if you want to check it out.
Serum 04.07.2006 12:38 AM
please share the link cspurlock.
cspurlock 04.07.2006 09:59 AM
http://forums.radiocontrolzone.com/s...d.php?t=217671
Serum 04.07.2006 10:13 AM
Joostin..
do yourself a favour and get an eagletree micro..
Promod 04.07.2006 10:15 AM
I've ran my 12.97 on 18 cells with the bec disconnected many times. No problems so far. Just disconnect the bec and get a receiver pack.
Thank you,
Promod
Serum 04.07.2006 10:35 AM
Didn't you even used it on 6S lipo? or is my mind playing tricks again...?
Promod 04.07.2006 12:04 PM
Yep, I've used the 12.97 with 6s lipo.
Thank you,
Promod
Serum 04.07.2006 01:41 PM
in the name of science...
joostin420 04.07.2006 03:22 PM
what is an eagletree micro...?
thanx,
justin
Serum 04.07.2006 03:36 PM
A must have.. :p
here, check it out.. !
http://www.eagletreesystems.com/MicroPower/micro.htm
coolhandcountry 04.07.2006 03:59 PM
So that mean the 12.97 is built like the 18.97 but with a built in bec.
