-   -   All about Jammin truggies & conversion. (https://www.rc-monster.com/forum/showthread.php?t=27620)
superek4 07.23.2010 11:45 PM
I have been with Hong nor/Jammin truggies for almost 5 years now & recently got sponsored by them.
I hope to help guys who are keen to convert or have problems with their truggies.
Pls post here to show off your jammin truggies or if need help.cheers!
superek4 07.25.2010 06:30 AM
My setup as follow
Hobbywing xerun 150amp with tekin 1550kv T motor
Acorn 6s 3800, 6s 4200 Lipo
X2 CRT with RCM motor mount
46 RCM slip diff
Pinion 14
superek4 09.05.2010 01:08 AM
Welcome! What motor mount are u thinking of the jammin conversion kit or Rc monster?
Bazzokajoe 09.05.2010 03:57 PM
any chance i could get some infomation from you?
what are the differences between the crt x2 and the normal crt x1,
is the x2 a hopped up race version? or is actually a redesign?
i am getting an x1 pretty soon and wanna know the differences so i can make a few small updates :)
superek4 09.05.2010 07:27 PM
All the cars are designed for race, that's why are pro kits.
X1 CRT has a bigger spur 62, whereas x2 CRT is 48. Internal gear ratio is different, x2 CRT diff is spiral, x2 CRT chassis is narrower n longer, all electronics n engine moved towards the center, x2 CRT has 16mm big bore shocks.
It's not worth it to upgrade x1 to x2 I made that mistake before, the chassis, universal, big bore, gears will cost u like a used x2 CRT.
Bazzokajoe 09.06.2010 02:23 PM
so basically as a basher, there's nothing i should do to it :)
cheers :)
VooDooCC 09.08.2010 12:50 AM
Looking at picking up an x1 crt, wondered which motor mount to go with. I'm thinking I read somewhere that the x1 mount limits gearing, and the buggy, x2 mount works better.
superek4 09.08.2010 01:13 AM
X1 CRT motor mount is higher n can be use in both x1 n x2 series. I m using it for all my jammin x2 n CRT. It allows me to use bigger pinions too.
Bazzokajoe 09.08.2010 03:44 PM
http://s136.photobucket.com/albums/q...hmerebear/CRT/
would you say all of that (not including electrics) is worth $300? as thats what the guy wants for it...
superek4 09.08.2010 06:30 PM
Too much to pay for a x1.
Bazzokajoe 09.09.2010 01:54 PM
how much would you pay for it?
superek4 09.11.2010 06:02 AM
A x1 CRT roller is only worth us$150-200 max.
Bmr4life 09.29.2010 02:09 PM
I paid $180 for a very nice X2 CRT roller.
http://i182.photobucket.com/albums/x...emr1/jamt1.jpg
How she sits now.
MMM Esc 2200kv motor (soon to be 1800kv 1y)
Turnigy 4s 5000 and 6s 5000 (speed runs only)
Losi Battery Tray
Pinion 14
http://i182.photobucket.com/albums/x...n/IMG_5010.jpg
http://i182.photobucket.com/albums/x...n/IMG_5014.jpg
superek4 09.29.2010 05:47 PM
Use the hong nor rx case;)
Bmr4life 09.29.2010 06:30 PM
I've got a couple waterproof traxxas rx cases I plan on using.
