full e-maxx transmission
Does anyone know if Mike can make a complete ready to drop in e-maxx transmission?
Or does anyone know where I can get one and how much? Thanks |
Mike can get you one.
with a stock case, FLM case, steel idlers, stock idlers.. i would take the steel idlers for sure.. |
I've sent him both pm and e-mail but no reply.
I will be using the single speed conversion but I have that. So I just need the remaining goodies, the idler and the case. I need a price so that I can tell my customer. |
anyone know a price?
You can get the aluminum half case from FLM for about $40 bucks. Don't know about the steel idlers I can't find them either but I am running the stock gears in my single speed and they are holding (knock on wood)
Good luck |
I don't need the FLM case or the single speed conversion. I have them. I just need the bearings and the other gears.
Anyone know what parts these are? maybe I can just buy them myself. |
http://www.rc-monster.com/proddetail...TRX3994&cat=17
http://www.rc-monster.com/proddetail...TRX3993&cat=17 http://www.rc-monster.com/proddetail...03idler&cat=41 or the below http://www.rc-monster.com/proddetail...TRX3996&cat=17 http://www.rc-monster.com/proddetail...TRX3985&cat=17 other than this you will need a slipper of your choice, a motor plate, and bearings. i didnt see the bearings in the store but the stock slipper pieces and motor plate are in mikes store. |
Hang on rcbros, help is on it's way..
You can just pay mike 15$ for the bearings you will need, thats what i did.
The last time I checked with mike I think it was about 90 for a trans with two speed and metal idlers. Don't hold me to this though.
well after studying the exploded views I think I found what I need. Keep in mind i'll be running the single speed conversion:
DuraTrax Bearing 5x11mm (4) $6.00 DuraTrax Bearing 6x12mm (4) $7.00 Traxxas Input Shaft Drive Gear E-Maxx $6.50 Traxxas Shaft Output E-Maxx $7.20 Traxxas Output Gear 31T E-Maxx $3.00 Traxxas Washer Teflon 6x8x5 (10) T-Maxx 2.5 $1.20 Traxxas Carrier/Drive Dog E-Maxx $3.90 |
All correct, but you dont need the carrier/drive dog in a single speed.
k thanks!
No problem..
try rcmonstermike@gmail.com for emails, william. I did find your pms
| All times are GMT -4. The time now is 01:28 PM. |
