Who makes aluminum rear hub carriers for RC8T
Just like the title says. Looking for another option besides the $70 rear hub carriers from Associated. Anyone know of an aftermarket set that is still strong??
M2C racing. Come with a larger hinge pin with 3mm nuts on each end and a drill bit to make the arm holes larger. $52.00 at amain.
What about King Headz products ?
I didn't see any in AMain. The M2C ones.
The problem I have with the m2c ones is opening the hole for the hinge pin. To me that seems like a dumb move considering your weakening the area around the hinge pin ultimately causing it to break first. With the added stress of having a alum carrier it would seem to be pretty dumb to weaken a part it connects to
| All times are GMT -4. The time now is 11:53 AM. |
