Can do motor dyno w/o load?
I just got a motor rmp & kv checker the instructions says can check the motor's kv n rpm. Is it ok? Or with load better?
The new firmware from Castle allows to check the motor Kv. And it's a no load test according to the manual, for example result is 2500Kv for the 1515/1Y 2200Kv motor (2200Kv is the Kv measured at load or max efficiency).
So I would say without load. |
| All times are GMT -4. The time now is 01:41 PM. |
