What size motor screws?
Just got kd36-74-9xl motor, using the kyosho motor mount but it didn't come with screws, and I'm wondering what size screws I should use.
The motor has holes in the endbell for 3mm screws.
I like to use 3mm cap head screws. |
Thanks, how about length? I know too long is bad, but so is too short.
Someone gave me this tip before: use a toothpick to see how deep the threads are until you contact the windings, then you can see how long of a screw you can use. Also, remember to factor in some length for going through the motor mount.
Thanx, I really didn't even think of something that simple.
| All times are GMT -4. The time now is 04:09 AM. |
