8ight owners help (chassis hole dimensions)
Can anyone give me these dimesions? (convert to mm please or leave in inches) Are the holes the same as on the Muggy chassis?
Rear end: http://img707.imageshack.us/img707/5008/produc40.jpg Need to know because of DE skids. Thanks Hope I'll get more help here than on RCtech.:oops: |
Forward - Aft distance edge to edge is 1.635"
Side - Side edge to edge distance is .936" Hole diameter is .18" Definitely not the same as the Muggy (I have both bare chassis plates on my bench) |
Oh well, gotta use another skidplate. Guess I'll just cut up my 2.5mm carbon sheet and use that. :whistle: Can you drill holes normally? (not scuffed up)
Also need to clarify - those dimensions are inside edge to inside edge on the CF. |
| All times are GMT -4. The time now is 05:49 AM. |
