-   -   Mamba Monster Amp rating? (https://www.rc-monster.com/forum/showthread.php?t=27711)
Dj_Sparky 08.01.2010 09:52 AM
I was wondering what the BURST rating of the Mamba Monster AMP is.
nuz69 08.02.2010 05:44 AM
Something like 500 or 600 amp ? Depends of what you call "burst".
Dj_Sparky 08.02.2010 06:27 AM
Was looking around at some info on what sort of amp rating the 1527/1y might kick up to, so I was just wondering about the burst rating of the mamba monster amp and what it could handle in worst case scenarios.
nuz69 08.02.2010 06:42 AM
The amp draw doesnt depend of the motor but of the application. A 1527/1Y will not consume the same amp in a 1:8 scale buggy or in a 20 lbs monstertruck, depending of the gearing and the acceleration ...
Anyway, the max continuous current of the 1527/1Y is the same of the 1515/1Y and of all the 15xx/1Y series. But its not the current that the motor draws, it's the max continuous current that the motor can handle without burning.
Dj_Sparky 08.02.2010 06:47 AM
Ah ok, thanks for clearing that up. I'm waiting for info on the diff ratio and final ratios etc on the Genesis differentials and transmission, but in the meantime I checked out the Flux tranny and gears with 12 pinion and 60 spur, aimed at 30mph top speed and 3 second to get there, and it only drew 30 amps. That would be a nice setup, sort of slow but ah well.
I'm guessing monster truck differentials are somewhat similar, so I'm estimating that I should be safe with a low pinion like 12 and 60 spur.
nuz69 08.02.2010 06:53 AM
Best solution is to try, don't hesitate to use punch control, it reduces a lot the spikes during kick-downs. Start for example with 80% and gear the truck for 30-35mph. It will be on 6S ? What the average weight of the truck ?
Dj_Sparky 08.02.2010 06:54 AM
Yes, 6s and it will probably weigh around 18lbs once I've installed everything. Waiting for the stuff still.
nuz69 08.02.2010 07:01 AM
I am pretty sure you can gear it for 35-40mph without issues. The mamba monster can handle the amp draw of a E revo (11lbs) geared for 70-75mph on 6S.
Dj_Sparky 08.02.2010 07:02 AM
Sounds good. A 18lbs truck running around at 75mph would be a little scary.. haha. :p
Should be possible with the 1527, no ? But I'm guessing I'd need a veery special esc. If anything can handle that.
nuz69 08.02.2010 07:22 AM
With proper cooling, and BIG BIG BIG ESC everything is possible. But without cooling a 1527/1Y should do anyway some speed runs at more than 100mph without overheating and with the proper ESC. All we need to do is to check the temps.
pinkpanda3310 08.02.2010 08:18 AM
Originally Posted by naynay12 (Post 292149)
Hopefully the tranny wil hold up with the cc2200kv which i plan to use.
Howmuch amps does the cc2200kv pull?
Originally Posted by Pdelcast (Post 292282)
From our testing about 200A on 4S and 350A+ on 6S during acceleration. Average draw at top speed is about 50A on 4S, and about 80A on 6S (at 50mph.)
This is from a thread about a savage. I know there not firm numbers but it might give you an idea.
Dj_Sparky 08.02.2010 08:25 AM
Ok, thank you. Looks like a 12 pinion on 6s with mamba monster will be fine then.
nuz69 08.02.2010 08:30 AM
In a 1:8 scale buggy, the power needed during acceleration to top speed (40mph) was 120-130A on 4S. The savage is a lot heavier so the measurments correspond.
