O'Donnell Z01B shock dimensions?
Hi!
Still looking for cheap and good shocks for my SC truck. Does anyone have the measurements for the O'Donnell Z01B front and rear buggy shocks? -front overall length: hole to hole length expanded: hole to hole length compressed: outer diameter of shock body: outer diameter of spring: diameter of shaft: -rear overall length: hole to hole length expanded: hole to hole length compressed: outer diameter of shock body: outer diameter of spring: diameter of shaft: Thank's a lot! |
Hello, I hope you achieve understand each other ...
I will be using the google translator ... The shock that I am measuring are the z01b team : Front: total length: 110mm orifice hole extended length: 100mm hole to hole compressed length: 74 mm outside diameter shock body: 19.5mm the diameter of the springs of both is: 25mm diameter of the capsule top: 22mm 4 mm diameter shaft Rear: total length: 134 mm hole to hole extended length: 124mm hole to hole compressed length: 90mm outside diameter shock body: 19.5mm diameter of the capsule top: 22mm the diameter of the springs of both is: 25mm 4 mm diameter shaft I hope to serve you Greetings from Argentina. |
Thank you very much, I understood everything perfectly.
Greetings back from Germany. |
| All times are GMT -4. The time now is 03:26 AM. |
