Silly question.
Just wondering, I have a warrior 9920 ESC and it only has one set of battery wires. To make things simple, could I just connect a deans plug onto the wires, and then make a dual deans plug adapter from this?
I would do what others have done with the wire between each pack, but would this not mean I would need a charger capable of charging an 18 cell pack? Sorry if these have been answered before, but I couldn't see these answered anywhere. |
Darren, please use the search button for 'wiring' or 'connecting'.
i just wanted to post you a link, but there are about 20 topics on this, please use the search. |
Serum - I couldn't see any answers to the two questions i asked, regarding the battery connections. I will still keep looking though.
You posted at the same time as me - Just so i get myself right here 2 male deans plugs - the positive from the ESC onto one deans, the negative onto another. The bit of wire between the two plugs will act like the wire between both packs, as used in this method, but it will allow both packs to be charged individualy? |
use the female plugs on the batteries, Male plugs on the controller. And yes you are able to charge the packs individually. (8 cells at a time) because they are separate from each other.
That is the way I used to do it darren when i ran the deans.
| All times are GMT -4. The time now is 12:59 AM. |
