-   -   castle/neu bearing fail? (https://www.rc-monster.com/forum/showthread.php?t=27759)
nvtuning 08.08.2010 07:46 AM
hey guys
the front bearing of my castle/neu 2200kv has alot of play on it
so much play the rotor touched the motor can.
Is this a often problem with the castle/neu ?
Because i just drove it for 4 battery's and didn't bashed it at all
here are some pics of my rotor you can see how it has some scares from touching the can
http://www.mijnalbum.nl/Album=JPLOSWYZ
greets nvt
Arct1k 08.08.2010 09:17 AM
Thats unusual I would drop an email to the guys at castle I imagine they will send you a rotor, endbell, bearing kit... Cheers
nvtuning 08.09.2010 01:08 PM
Can i have some respons from people from castle.
Because i recently mailed castle and they told me to ship my motor.
But that would cost my as much as buying a repair set because i live in europe.
I also think pics say enought to see that this is under warranty?
greets nvt
suicideneil 08.09.2010 10:57 PM
A replacement bearing would be the quickest solution if sending it in is too costly- not sure on the size but the original should pop out if you tap it with a dowel rod an a mallet gently.
nvtuning 08.10.2010 04:43 AM
I know i could replace the bearing but my rotor is damaged by hitting the can
because of a worn out bearing so only a bearing wouldn't do the trick.
I already check my motor can its still fine its just the rotor and the front bearing.
Shipping my motor to the usa would cost me about 30 dollar so that pretty expensive i think.
greets nvt
Arct1k 08.10.2010 07:28 AM
The problem is castle probably want to look at the failure. It's worth another email or call to see if they won't just get you a rebuild kit.
suicideneil 08.10.2010 08:58 AM
Thats probably why they want it sent in, yeah.
The rotor doesnt look 'damaged' really, its just worn off a batch of the kevlar wrap- you could buy some kevlar string and re-wrap it yourself, otherwise see if Castle are willing to just send you a repair kit like Art1k said.
nvtuning 08.10.2010 09:03 AM
I can't just rap a new kevlar around it needs to be lined out correctly.
but i hope to get some anser from people from castle there self what they thought.
The girl from castle understood my thinking about the shipping be to expansive
but she couldn't do much about it.
So thats why i asked here because here are many people from castle on the form
greets nvt
hope castle helps me out
Arct1k 08.10.2010 09:23 AM
Try tech support again but ask for Thomas or Joe...
nvtuning 08.10.2010 10:02 AM
pm'ed patrick waiting for answer
greets nvt
nuz69 08.11.2010 11:07 AM
Did you try to lubricate the bearing ?? You must not do it, it would prematurely kill the bearing. The bearing shouldn't need maintenance for a long long long time, that's not normal yours died after 4 packs.
nvtuning 08.11.2010 11:36 AM
i havn't done anything to it just some 4-5 cells runs in my street to see what is does and one time on the track i didn't put oil or other stuff on/in the bearing
greets nvt
Thomas Porfert 08.11.2010 12:21 PM
nvt,
Shoot me an e-mail directly and I'll get you setup with a rebuild kit. These things can happen and I understand not wanting to wait for the long shipping delays; not to mention the shipping costs. My e-mail is thomas (at) castlecreations (dot) com and I'll get you setup.
Thomas Porfert
Castle Tech Support
nvtuning 08.11.2010 12:33 PM
Originally Posted by Thomas Porfert (Post 376449)
nvt,
Thomas Porfert
Castle Tech Support
you've got mail
thanks very much thomas
nvtuning 08.18.2010 01:49 PM
I just received my castle repair set, going to install it this weekend.
Thats for the great service castle!!
I was thinking about buying a tekin if my mmm would die,
but after this it will be a mmm again!!!!
!!Great service and nice products castle rocks!!
greets nvt
