-   -   MMM 2200KV sounding like a Electric Drill ?? (https://www.rc-monster.com/forum/showthread.php?t=27832)
sabongi 08.16.2010 02:45 PM
Just got my MMM, took it out of the box, installed EC5 plugs and ran it.
Motor is making a electric drill sound, something like a really bad bearing or something.
What can i do?
I'm in Brazil, so it would take 1 month to send it back, and probably 2 months to receive it back from you.
Can't afford waiting all this time. Is there something i can do?
Bearing oil maybe?
nvtuning 08.16.2010 03:15 PM
if your rotor isn't damaged and you are willing to drive again soon buy a new bearing others you wil need to contact tech support
greets nvt
bruce750i 08.16.2010 03:26 PM
Both are/have electric motors and may sound alike.
Did you run the 2200 installed in a Rc or just holding it in your hand?
Does your electric drill run okay or does it get hot and smoke?
You can take the 2200 apart pretty easy to take a look around inside. Take the front end bell off and install a pinion(for grip and to hold bushing on shaft) then slowly and strongly pull the rotor out. Note the number of bushing on the shaft on both sides of magnets. It should have some clay on the end of the rotor where it was balancing.
DCastaneda 08.16.2010 03:43 PM
I have a CC 1512 1.5Y that has a distinct "click" over one spot in the rotation of the rotor. Took it apart bearings fine rotor looks ok to me. Any ideas?
sabongi 08.16.2010 04:20 PM
It was in my hand!
Runs ok, no heat or smoke!
Took it apart, only one bushing on the front and another on the back. Bearings look ok.
Anything else?
Maybe too much axial play?
Maybe the brass bushing size is wrong?
bryan 08.16.2010 08:09 PM
Are you reffering to the noise that a cordless drill w/a clutch sounds like?
93firebird 08.16.2010 09:14 PM
I thought you weren't supposed to run them with out having them installed in a vehicle!!
Freezebyte 08.16.2010 09:46 PM
Uh dude, I hate to tell you this but you NEVER want to run a brushless motor without any kind of a load on it. I think you just blew the bearings
sabongi 08.16.2010 09:56 PM
i never got to full throttle, just below middle...
bryan 08.16.2010 09:57 PM
Actually running the motor with no pinion at WOT is required for the new motor/kv test.
Personally
I think he blew a diff.
sabongi 08.16.2010 10:00 PM
The motor was in my hand... out of the car...
bryan 08.16.2010 10:20 PM
Please attatch pix of what you are doing.These motors are very "notchy" with no power applied.Or FREEZE may be right and you did f up a bearing?
Freezebyte 08.16.2010 11:13 PM
Noo............... try again
http://www.rctech.net/forum/electric...motor-get.html
http://e-savage.com/forums/showthread.php?t=4527
http://www.rcgroups.com/forums/showthread.php?t=119101
jholthus 08.16.2010 11:18 PM
In the castle link software when you do the KV motor test it tells you to either pull the motor away from the spur so there is no load on the motor or just take the pinion off the motor.
bryan 08.16.2010 11:26 PM
Sorry FREEZE.but those links have nothing to to do with the motor k/v test that are now offered through the castle link
