-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   Please help with G3R build (https://www.rc-monster.com/forum/showthread.php?t=27839)
Zyoss32 08.16.2010 11:01 PM
I am building for the first time and have my g3r together except for the tranny and drivetrain, I want to use a center diff and mike's center motor mount but I need the specifics to know what to buy and not waste money. Can someone please walk me through exactly what to buy brand model # for the parts i will need to finish this project, I have 3 motor options tekin 1700kv, 1515 neu 3d,
1521 neu can use any of these what changes do i need to do for the drive train also do i half to have special made or can i buy one to work with one of these motors. if need special made what length and who can do this for me, I know alot of you have done this build and have that info so i can copy.thanks so much i need a lot of advice i know.
Clayce
suicideneil 08.17.2010 07:28 PM
The only custom parts you will need are the center dogbones- most people would get Mike to make them to the length they require; the length will depend on how you position the centerdiff unit exactly on the lower plate of the G3r chassis ( custom installation that requires drilling 4 holes ). The only other thing you need is an actual centerdiff; ofna or hotbodies being the usual choices unless you opt for one of Mike's slipperentials.
Gearing will depend on the kv of the motor, the voltage you run & the size of the tires; you have BrianG's calculator to help you there:
http://www.scriptasylum.com/rc_speed/_top_speed.html
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 9
Total Voltage: 22.2
Motor KV: 1700
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 6 : 1
Total Ratio: 17.07692 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Rollout: 1.09:1
Total Motor Speed: 37740 RPM
Vehicle Speed: 38.79 mph (62.31 km/h)
Effective KV Value: 1700
As an example of the setup required when using the tekin 1700kv motor- geared for ~40mph on 6s lipo with stock talon tires. Not sure on the maximum size of spur you can use, its been discussed a few times- check the slipperential threads:
http://www.rc-monster.com/forum/forumdisplay.php?f=45
Often people use dogbones from other vehicles that happen to the the correct length, takes a bit of research, though BrianG again has a helpful page:
http://www.scriptasylum.com/rc_speed/_dogbones.html
Otherwise you could probably just use the stock plastic driveshafts form the erevo or emaxx, and cut them to length as required ( pair of longer ones and trim down ).
Zyoss32 08.18.2010 11:51 AM
I need to purchase the
1/8 center slipperential Diff for $119.99
Universal Center Diff/motor Mount for $89.99
And then place on chassis and get dogbones mad to fit.
and i am in business.
Just making sure before ordering items
thanks Neil. for help I will be running the proline 40 series bow ties as tires
thinking of going with the 50t spur on slipper
