Calculating runtimes
Is there a way of calculating the run times by voltage/capacity of batteries and RPM of the motor with weight?
I'm sure nearly everything effects it but wondering if there is any rough calculation to knowing. |
There are soooo many factors that affect runtime, that to be honest, a good guess would be as accurate as any calculation. The main thing that affects runtime is driving style, and theres no real way of integrating this into a calculation, seeing as everyone drives in a different style.
Amen maxxdude..
just do a testrun, it saves you a few days of calculating. |
how much runtime/speed do you think i'll get?:
10xl 22.2 volts 8000mah 12lb truck 15020 warrior any guess is fine. |
I would guess someone around 45-60minutes. Very long in other words.
The idea was to know before I BUY new batteries. :P
I'm sure if you tell us your set-up we could give a rough estimate of runtime.
How about somthing like this:
10L 14.8V 6000mah 9.5lb truck 9920 |
About 40 minutes I would guess
How about this...
540C-9L Genesis Truck esc 12 Matched GP3300 cells 1/8th Jammin X1-CR buggy Thanks alot! |
i would guess around 12-15 minutes depending on how you drive it.
Thanks, I will probably upgrade to IB4200's. Should boost the runtime up to about 17-19 minutes? That would be awesome...Thanks again.
yea, somewhere around there. 15 minutes should be pretty easy.
| All times are GMT -4. The time now is 07:18 PM. |
