hv motor sensor wire replacement
anyone know who to take the hv motors apart so i can remove the sensor wire and solder a new one on?
thanks |
Remove front endbell and rotor Remove the rear bearing cover Unsolder the stator coil leads Remove the rear endbell Remove the sensor board Remove wires from sensor board Solder new wires to sensor board Reverse the rest of the disassembly process. |
i have the skill just wasnt sure if i had to desolder the stator or now
Listen to mr i know everything. The only way hes going to learn is by doing it
Just say what you got to say don,t use initials.the guy was lookin for help and you have to give him some wise ass answer.typical jerk off
why are you here?? |
| All times are GMT -4. The time now is 10:24 AM. |
