-   Mini truggy (https://www.rc-monster.com/forum/forumdisplay.php?f=43)
-   -   What center driveshaft lengths for RC-M CRT.5 chassis? (https://www.rc-monster.com/forum/showthread.php?t=27885)
g-townmach 08.22.2010 10:59 AM
Just wondering what the center driveshaft lengths are for the RC-Monster CRT.5 long chassis.
I heard a while ago that the front is the same length as the stock rear, which is 82.5mm I believe. Just wanted to see if thats true.
If so, that would be super nice having the same length front and rear when it came time for replacing one or both of them.
g-townmach 12.07.2010 08:47 AM
Does anyone have an answer for this??
It would really convince me to convert to the rc-m extended chassis if I knew the driveshafts were a readily available replacement part. Thanks.
silentsnow31802 01.12.2011 06:00 PM
I just ordered one so I will measure the shafts when it arrives. I can also measure the stock ones if you would like.
Arct1k 01.12.2011 06:15 PM
They are just rears IIRC from a normal CRT.5
silentsnow31802 01.30.2011 01:29 AM
Just got my chassis today. It came with one driveshaft that is used for the rear. The kit has you use the stock rear crt.5 shaft for the front.
Rear shaft (came with kit) - 88.18mm
Stock rear CRT.5 shaft (now used for front) - 82.39mm
brainanator 01.30.2011 02:38 AM
good info, thanks silent.
