1/8 diff output shaft
does anybody know the answer if the this rc-monster part will work in a standard center diff as an output and accept an output cup? i'm wondering if it will work and accept the sun gear inside the diff. the description sounds like its made for front or rear diffs but i need something like it for a center diff.
Should work anywhere... a center diff is just a rear diff with some different cups and a spur instead of a ring gear. I had to shave mine down a hair to fit in 8ight diffs, but they should work just about anywhere.
good news, i just don't have extra to guess on parts fitting. i had issues with CEN stuff fitting into my other stuff so i'm trying to work around that.
| All times are GMT -4. The time now is 11:44 AM. |
