Kyosho MFR question
mfr use center gearbox not center diff so i think it will not fit without many modification.
i have many curisity to see one of those converted to brushless. |
Indeed:
http://radiocontrolzone.com/attachme...1&d=1211317440 No way in hell to use a centerdiff mount work with that tranny- you'd need to come up with a custom mount so that the motor is securely mounted to the chassis & can mesh against the lower half of the exposed spur. Otherwise, rip out the tranny and install any centerdiff unit you want- its only 4 holes that need drilling afterall really ( and maybe a slot for the spur ). |
OK, thanks for the info, ahdn't thought about the missing centerdiff :surprised:
I will have to figure out a solution on this? |
| All times are GMT -4. The time now is 05:11 PM. |
