New Venom packs
With rather confusing specs;
www.venom-group.com/itemdesc.asp?ic=15060 Specifications: Battery Type: Lithium Polymer (LiPO) Configuration: 2S2P Weight: 10.25 oz. Dimensions: 23.5 x 46.5 x 137.5mm Charge Rate: 1C (5A) Continuous Discharge: 60C (300A) Min Discharge Volts Per Pack: 6V Max Burst Rate: 600C (500A) Max Volts Per Cell: 4.2V Max Volts Per Pack: 8.4V Watt Hours: 37 Umm, what...? |
They must have meant to put 100C for max burst, but made an error.
Don't tell Austin but someone took a page out of Maxamps' book!
2s2p, enough of a red light right there.
I am biased I am sorry, I purchase 4 2s2p zippys. I only have one left, and it poofs quite a bit now after a hot day run to lvc.
So now I am careful about the 2p or xp batteries. I know their characteristics. |
Allright, valid points then.
| All times are GMT -4. The time now is 07:46 AM. |
