-   -   Rustler Shafts ??? (https://www.rc-monster.com/forum/showthread.php?t=28050)
radioman193 09.10.2010 01:33 AM
Rustler Shafts ???
Is there an upgrade for the Rustlers Cv's
or what shafts will work on the Rustler?
_paralyzed_ 09.10.2010 01:42 AM
FLM shafts FTW
What's_nitro? 09.10.2010 02:12 AM
Yeah Mike sells the FLM stuff. I believe you need to replace the stub axles and maybe the rear arms/carriers (with FLM) for the FLM CVDs to work. I'm not sure since I don't have the FLM CVDs on my Rustler. I'm using the MIP kit which I like very much, just FYI...
_paralyzed_ 09.10.2010 03:22 AM
FLM makes a drop in kit for the rustler, no upgrades needed. $48 part # FLM26315
Nard Cox 09.10.2010 07:04 AM
After breaking four output yokes in a week I replaced them with Traxxas #5550 (IIRC) Traxxas Jato drive shafts. A cheap option, 1 minute customizing and I didn't break a driveshaft again.
What's_nitro? 09.10.2010 08:26 AM
I thought they did... but in the RCM store Mike only has two FLM CVD kits and they both require additional parts per the description. :neutral:
_paralyzed_ 09.10.2010 08:47 AM
It's this one http://www.rc-monster.com/proddetail...M26315slashcvd
It is confusing because it doesn't specify that it fits the rustler, but I assure you the 2wd slash rear end and the rustler rear end are one and the same and that these cvd's help the ol' rusty out:yes:
nitrostarter 09.10.2010 09:33 AM
Correction: For a Stock Rustler or Stampede, you need this kit: http://www.rc-monster.com/proddetail...lm26515&cat=31
I just installed this kit a month ago on my Rustler. No probs and super strong!
_paralyzed_ 09.10.2010 09:46 AM
That is the correct dogbone kit, OP was asking for cvd's
nitrostarter 09.10.2010 10:27 AM
Si Senor. But the picture is old. Read the description. I definitely received new model CVD's.
