-   -   Lightning Stadium Pro shock question (https://www.rc-monster.com/forum/showthread.php?t=28074)
jamesban 09.13.2010 10:57 AM
I picked up a nice Lightning Stadium pro roller and have it going well brushelss but the shocks are blown. Rather than find a rebuild kit for them are there any better shocks that are a direct fit that anyone knows of? Thanks.
brushlessboy16 09.13.2010 11:05 AM
How long are the shocks front and rear?
Bondonutz 09.13.2010 11:13 AM
The Aluminum Purple capped HotBodies shocks are of excellent qaulity and are definitely worth the small expense and time rebuilding IMO.
Rebuild kits for these shocks can be found despite being discontinued.
Go to Hotbodies site and get the part number for your application and do a search on Ebay and google. I'll bet you can rebuild all 4 shocks like new parts and S&H for under $20.00 easy.
If you have the shocks that are half plastic and half aluminum capped then replacement might be best. All you need is roughly the same over all lenth and look at Ofna, Losi, Associated etc for what you think is best for your budget and needs.
Good Luck
Semi Pro 09.13.2010 06:02 PM
the hot bodies shocks are great, no reason to change them
jamesban 09.13.2010 09:12 PM
they are non adjustable gray aluminum with purple caps. I guess they are the stock ones then? I shall see if I can find a rebuild kit. I do not see the part number on the HB site though.
Semi Pro 09.13.2010 11:26 PM
look on amain, they use the same rebuild as gs racing
jamesban 09.14.2010 08:41 AM
What weight oil should I use for bashing when I rebuild the shocks?
jamesban 09.14.2010 12:02 PM
damn its confusing to find the right rebuild kit for these. There are the lightning stadium pro, the lightning pro, the pro 2 of each and now the 10th scale version of each. Some list part numbers some dont, you cant tell by looking at the pictures of the shock shafts and parts which are correct?
Bondonutz 09.14.2010 01:02 PM
Please post EXACTLY what model you have, I know the HB site well and can help but need info to do it.
Couple pics might help as well.
jamesban 09.14.2010 03:08 PM
I can post many pics. I bought it used though and have no other information on it.
Bondonutz 09.14.2010 03:18 PM
Just a decent over all pic is needed
jamesban 09.14.2010 07:43 PM
3 Attachment(s)
here they are:
Bondonutz 09.14.2010 07:59 PM
Great news for you, Looks like you have a "Lightning Stadium Pro2"
Fab truck !!! I have one myself. These are the first generation Truggys, this is obvisously the second version of this truck but this is where the "Truggy" classes started. You own a small piece of RC History so to speak.
The 2nd Gen/Pro 2 has lots of features the first did not. Carbon fiber pieces,cnc'd fron and rear hubs and I think hardened diff gears was standard ? I'm sure a few more things but they escape me.
This is your truck
http://www.hotbodiesonline.com/kit.p...b66200&lang=en
Heres the part # HBC8107-2
http://www.hotbodiesonline.com/produ...hbc8107-2.html
Dont let the term "rear shock rebuild kit", they are the same as the rear lightning buggy shocks.
I looked on ebay and googled and unfortunately did'nt find anything right away, it doesn't mean they aren't availible. Be patient and look around some, I will myself.
If the rebuild kits are obtainable and be found at a good price these shocks are def worth spending the $$ on. They are very stout and work well, if the shock body insides are not worn they will last a very long time and provide excellent service.
Bondonutz 09.14.2010 08:00 PM
Never thought to ask, you here in the states ?
HB parts are very readily availible across the pond, they love these things over there ?
jamesban 09.14.2010 08:23 PM
I live in the states. Near Detroit unfortunately. I thought the guy I bought it from told me it was a lightning stadium pro but he added some parts to make it like a version 2 but either way I like the truck but the shocks have no rebound and it rides a little bit too low. I found these on Ebay:
http://cgi.ebay.com/HOT-BODIES-C8107...item3f00632db8
So I just order 2 sets of the "rears"?? Hopefully this will fix them right up!
Also right now im running a 14 tooth pinion with a 2250 motor on 4 cell A123's. It moves pretty good but Im thinking of upping the pinion a few teeth. What do most people run for their pinion with this setup?
