-   -   1717 in a Desert Boy Chassis, It can be done ! (https://www.rc-monster.com/forum/showthread.php?t=28168)
Bondonutz 09.25.2010 03:00 PM
Since I bought another 1717 I thought I squeeze my 1717 Heli version into my DB-17 chassis. Hope this well help you fellas wanting to do the same ?
The 1717 Heli version is needed unless you grind one side of the can flat ?
Use a dremel deburing bit to hog out the 3mm slots on a FLM or RCM Revo 3.3 Nitro conversion mount.
This is the gimmick I used and it made short work of the aluminum, a small round file will work but you'll be there a while.
http://i88.photobucket.com/albums/k1...E/P9240011.jpg
1717 installed
http://i88.photobucket.com/albums/k1...E/P9240013.jpg
http://i88.photobucket.com/albums/k1...E/P9240014.jpg
I then cut a piece of 2" X 3" X 3/16" flat stock and drilled and tapped holes (4mm)for it to be mounted where the original Flux mount went on the motor plate.
http://i88.photobucket.com/albums/k1...E/P9240015.jpg
I then eyeballed where I wanted the mount to be on the tapped plate for optimum gear choice (I can easily use a 10T pinion up to at least a 18T with the way I've done this) I counter sunk the holes that the hardware attaches the FLM/RCM mount to the plate.
http://i88.photobucket.com/albums/k1...E/P9240016.jpg
http://i88.photobucket.com/albums/k1...E/P9240017.jpg
Then once all together I placed the assembly on the Flux motor mount plate and eyeballed where I needed to trim the chassis to allow the FatBoy 1717. I didn't have to remove much, it took a little bit because I had to cut a little reinstall, cut a little etc etc. After I filed the cut edges I ran over the shiney alum w/a black sharpie.
http://i88.photobucket.com/albums/k1...E/P9240018.jpg
http://i88.photobucket.com/albums/k1...E/P9240019.jpg
http://i88.photobucket.com/albums/k1...E/P9240020.jpg
The draw back to stuffing this pig in here is I have to relocate the servo from the original FLM servo plate and reinstall on the side of the chassis rail but I'm not comlaining.
LiqrSicc 09.25.2010 05:51 PM
Nice! I was hoping somebody would figure this out. I just wish the 1717 came at a higher kv. On 6s I dont think you can even reach 50mph with the highest gearing.
mac3194 09.26.2010 12:47 PM
i hope we can see a video of this monster in action!
Bondonutz 09.26.2010 01:16 PM
I'm working on it as I write this post, I hope to have it all together today but I think I'm gonna swap out the RPMs for the stock arms and I have a pin wedged in the FLM bulk. Should be fun getting out ?
Video soon
BrianG 09.26.2010 01:49 PM
You could use 10" diameter tires. :smile:
Nard Cox 09.27.2010 03:25 AM
That's the motor mount the FLM FTC set has right? Are you saying it will fit without a problem?? I ordered a 1717, but the normal version because I thought it would never fit anyway ...
What is the diameter of the shaved side of the 1717 Heli?
EDIT: 46mm, it's on the site ...
Bmr4life 09.27.2010 08:40 AM
It will. Just put a 25tooth pinion and install the high speed idler. I did the math. My db17 does 50mph with small racing truggy tires on 4s with the 20t pinion, high speed idler, and 2200kv motor.
Bondonutz 09.27.2010 04:42 PM
Fast Lane Machine Bulkheads and HPI Anti Sway Bar kit
I had to do a bit of modding to get the sway kit to work w/the FLM bulks but it can be done with some patience and a 3mm drill&tap.
As you see I trimmed the front of the bulkhead down with a dremel wheel and hand file. I mocked the sway bar stay and marked holes, drilled and tapped.
http://i88.photobucket.com/albums/k1...E/P9270021.jpg
Iwas able to use the little caps that are supposed to retain the upper arm pins, this took some modding also. I had to trim some plastic on 3 areas of the cap but it looks like It's supposed to after installation.
http://i88.photobucket.com/albums/k1...E/P9270022.jpg
http://i88.photobucket.com/albums/k1...E/P9270023.jpg
http://i88.photobucket.com/albums/k1...E/P9270024.jpg
Just need to do the rear sway now, I hope this is the last of the stuff I have to do to this thing far as mods. Ben tinkering on and off for almost a week again and getting anxious to drive this thing. I also hope(I am somewhat confident) that the sways will aid the handleing quit a bit but we'll see I reckon ?
Doh, Just remembered I found some Proline 23mm 40series 1/2offsets that I have coming. I need to drill holes in the face of the velocity rims and then dye Black and install the tires. Not sure what I'm gonna use, probably the Losi ATX's. I know they are fairly common but they are a great tires for all around traction and durable. I may snipe them for more tread flex and better grip. I'll see how ambitous I am when they mounted ?
thzero 09.27.2010 04:52 PM
FLM really needs to update their machining for the Savage bulkheads so that it works with the introduced swaybar kit.
Have fun with the crappy 23mm ProLine hubs... I destroyed like 4 of them within a span of a couple weeks. Much rather stick with the 17mm standard hubs (or go with the 24mm HPI hubs).
Bondonutz 09.27.2010 05:59 PM
Not useing PatheticLine 23mm hubs, A company called American CNC Machine makes far superior 23mm hubs for most applications and they are usaully much cheaper.
For LST2/XXL applications the CEN stock 23mm hubs are the bomb, super cheap and they are steel.
These are for a REVO/Maxx but you get the idea
http://cgi.ebay.com/23-MM-Hub-Hex-Se...item53de924e5a
thzero 09.27.2010 06:16 PM
Ah, good info...
JThiessen 09.27.2010 09:48 PM
Nice work on the sway bar mount Bondo. Taking those ears off completely looks like it was definitely the trick - yours looks like it fits better than mine ended up. Now get this thing runnin!
Bondonutz 09.28.2010 08:16 AM
Thanks JT, I'm trying to get R done ! Ben strugggleing with finding time to do so.
mini_t racer 09.28.2010 12:29 PM
you have a great project mate but what is the red part fitted to the spur gear if i may ask
JThiessen 09.28.2010 01:01 PM
Looks like a home made spring washer (rubber o-ring)????
