-   -   Mamba Max Pro or Monster for 1512 (1800kv) on 4s (https://www.rc-monster.com/forum/showthread.php?t=28259)
crusey_aus 10.09.2010 09:08 AM
Gday Folks,
Just wondering what the reccomendation for an ESC would be for the 1512 (1800kv) running 4s in a Slash 4x4
If I choose the Pro, I assume I can shorten the ESC wires and add 6.5mm bullets
Will I need to change timing from the default ?
I was thinking of gearing it 21/50 to start with and maybe even 25/50 if temps are ok
Will just be used for bashing
Cheers
Arct1k 10.09.2010 10:04 AM
MMPro will be fine but with a HT servo you may need a BEC or just go with a MMM
kingdomracer 10.09.2010 11:48 PM
I run a MMP w/1512 1.5Y Castle-Neu motor with no probs on 4s.
However I had to install a CC BEC to run a 7945TH.
My install of the CC BEC is different than the instructions, I still use the internal BEC from the MMP to power the radio and transponder.
While the CC BEC just powers the servo. I use a Y-adapter for the CC BEC and servo with the red wires connected to each other on the servo/bec side and the part that goes into the radio the red wire is disconnected. This is the ONLY true fix for using the MMP with a high voltage servo before going to a CC BEC PRO.
crusey_aus 11.04.2010 08:12 AM
Gday folks,
Installed the MMM / 1512 (1800kv) today in my Slash 4x4 and I love it
Running 4s at the moment but will try 5s in the next few days
However the bec doesnt seem to be coping, my RX voltage is dropping to below 5v (running an ACE DS1015 servo) but not browning out
Will install an external bec to rule it out
Cheers
Arct1k 11.04.2010 08:47 AM
Yes but check your end points as you maybe stalling out the servo - the MMM has a pretty solid BEC.
After getting into rock crawling though I normally just add a BEC to all my setups now...
crusey_aus 11.05.2010 12:56 AM
Thanks for the response Arctik
Dialed back the steering servo EPA to 70% as suggested but the problem still exists
Installed an external bec and the problem goes away
Cheers
Jahay 11.08.2010 06:39 AM
forgive my ignorance...
what does the BEC do? control voltage to servo?
where is it placed?
how much are they?
what is a decent one?
Thanks
BIG-block 11.08.2010 02:36 PM
where is it placed?
how much are they?
Thanks
Have a read of this. Might give you some of the info you are after. CLICK HERE.
Most people use external BECs if they have a HV ESC, which usually don't have a BEC at all, and people that want to use servos that draw more current or operate at higher voltages than the ESCs BEC can suport. I have three cars all running the Castle Creations BEC and so far they have been bulletproof. Also love the way you can set the voltage to anything you desire.
On one of my MTs I am using a Turnigy HV servo to twist the Big Joes tires I have and it does it so easily. I have the BEC set to 8.2 volts and I am also running a whole bunch of LEDs of it too. Great piece of gear the CC BEC is.
Jahay 11.08.2010 04:16 PM
Thanks a lot! Ill have a look now!
kingdomracer 11.18.2010 11:08 PM
I've been thinking about this post and would like to know if turning down steering rate is just the same as setting the travel lower than 100% (EPA on DX3R is travel).
crusey_aus 11.19.2010 07:23 AM
Same effect as far as I know one is accessed via the menu (travel / epa) while the other is easily adjusted on the fly via a knob (rate)
Cheers
immarcescibile 12.02.2010 05:46 AM
Hi guys, I'll soon have a Mamba Monster Pro + a Castle Creations Ext.Bec on my Mugen MBX6 electrified...
I'd like to know if there's anyone of you who can tell me wich voltage should I choose for an ACE1015 steering servo please...
Thanks..:lol:
crusey_aus 12.02.2010 07:14 AM
I use the same Servo and my Castle ccbec is set for 6v
I use the Spektrum DX3s and have servo travel set at 75%
Cheers
immarcescibile 12.02.2010 08:12 AM
Perfect I'll have a 3PK radio + Spektrum module, should check for the end-points, isn't it??
crusey_aus 12.02.2010 08:33 AM
Yes mate same thing
Cheers
