-   -   single 4s or..... (https://www.rc-monster.com/forum/showthread.php?t=28328)
kneedeeppow 10.15.2010 07:30 PM
single 4s or.....
hey guys
i have been running a 4s 5000 in my mbx5t and getting 13-14 minute run times. am moving on to a rc8t and thought now might be the time to explore other avenues of power sources to try and break the 15 minute plus mark(to compete in finals-if i every make one:whistle:) would running 2x 2s 5200s give anymore than a 4s? am running mmm v3 w 2200kv,would the mmm handle 2 x 4s?
cheers
pow
_paralyzed_ 10.18.2010 02:50 AM
yes, 2 x 2s 5200 would yield 200mah more than a 4s 5000. But 200mah really isn't much, maybe another minute or two of runtime.
The MMM can handle 2 x4s IF THEY ARE WIRED IN PARALLEL (positive to positive and negative to negative) And if you had 2 4s 5000mah batteries wired in parallel it would equal 10,000mah and give you twice the runtime.
The MMM CANNOT handle 2 x 4s wired in series, that doubles the voltage and the voltage limit is 6s. (2 x 4s wired in series equals 8s)
Any other questions?
kneedeeppow 10.19.2010 01:51 AM
we have to run hardcase lipos here for events and 4s hardcase lipos are far to expensive for my budget so running 2 2s hc lipos is the next option(hobbyking 2s hardcase packs are cheap and seem to be good value for $)
_paralyzed_ 10.20.2010 12:35 AM
hobbycity has a sweet 4s hardcase pack too
_paralyzed_ 10.20.2010 12:40 AM
you're really close to the 15 minute mark already, so the extra 200mah might be enough.
You could also try a pinion with 1 or 2 less teeth. The lighter load might just give you the increase in runtime that you need. But of couirse check temperature often when changing gearing.
Good luck!!
