-   -   My upgrade e-revo (Wea) (https://www.rc-monster.com/forum/showthread.php?t=28336)
Wea 10.17.2010 01:57 AM
http://picasaweb.google.ru/Wea1989/x...eat=directlink :party:
Она едет ещё в перевернутом состоянии.
molak 10.17.2010 02:18 AM
crazy!
remie 10.17.2010 06:02 AM
You're a genius!!!
I was thinking about the same thing, but then with the motor mounted on top of the chassis instead of underneath it, and using a center diff.
Can you tell us a bit more about the parts that u used, and what kind of motor, esc and lipo combo you're using.
Kind regards remie
Wea 10.17.2010 09:49 AM
Motor medusa 3680(1600Kv), ESC mamba monster, Lipo- turnigy 5200 30C 2s, servo 1015 as.
Setup spur 36, pinion 19, 2s lipo. Speed 54 km/h
Muggydude 10.17.2010 10:48 AM
Wow, amazing! I can see that being one heck of a racer! My only problem is how the motor wires are exposed to be scraped on the bottom of the chassis. Could you route them up through the chassis on top?
Wea 10.17.2010 03:48 PM
У меня 2 e-revo и всего 1 esc я его перекидываю с одной шасси на другую. Провода можно убрать полностью.
suicideneil 10.17.2010 07:41 PM
Originally Posted by bing translator
I have 2 e-revo and only 1 esc I perekidyvaû from one chassis to another. Cables can be removed completely.
The wires are a bit exposed yeah, depends if the track is just dirt or has any small rocks or whatever to snag the wires on- routing would be simple enough though.
Really impressive build though, having the motor under-slung is a stroke of genius with the compact centerdiff/ spool unit to save space. I like the battery connector concept, though I'd want something to make a cleaner contact between the battery and panel- that mass of wire & solder looks a little bit iffy to me; Im thinking springy curved panel on the lipo, like how a deans connector works maybe..
Drivinfast247 10.19.2010 01:28 AM
:surprised: Nice!!
el tomaso 10.19.2010 11:42 PM
Smart build!
TG
fastlane01 01.18.2011 12:04 AM
Originally Posted by remie (Post 384304)
You're a genius!!!
Kind regards remie
Yeah! That would be the way to go. I wish some one could make a mount.
E-Revonut 01.18.2011 01:55 AM
Just seen this!!! That is by far the coolest revo I have ever seen! Personally I would have flipped the center diff/motor mount and put the motor on top. It would have raised the CoG a little but still much lower than any other Revo out there, and you would all the ground clearance still. Overall, it's still an incredible build.
Semi Pro 01.18.2011 08:50 PM
sehr nette bauen, viele von uns haben gesprochen, die die gleiche Sache mit outrunner Motoren
Wea 01.22.2011 06:58 PM
Hi all!
http://www.youtube.com/watch?feature...&v=JIbQtH4u4B4
http://www.youtube.com/watch?feature...&v=ScYF8Hry7bQ
http://www.youtube.com/watch?v=XSm2s...ayer_embedded#!
George16 01.22.2011 07:42 PM
Great vidoes!!!!!
Urgeoner 01.23.2011 12:30 PM
pretty slick...reminds me of that old tyco car that could be driven whether it was right side up or upside down...the ricochet or something like that. much props!!
