-   -   motor mount screws (https://www.rc-monster.com/forum/showthread.php?t=2836)
tallyram 04.13.2006 09:29 PM
motor mount screws
i've got an lmt 1950 motor that will be mounted to a traxxas emaxx motor plate that is 4mm thick. add 2.5mm for the depth of the hole in the motor. add .2mm for the thickness of the washer. do i need a 6.7mm long screw. where can i get a length like this? please help.
tallyram 04.13.2006 09:32 PM
do i just use 2 or 3 washers to compensate for a screw that is to long?
MetalMan 04.13.2006 09:50 PM
If you have a Dremel, you could cut the screw down. As opposed to using extra washers, this method will provide a stronger hold.
squeeforever 04.13.2006 10:33 PM
if you do that just remember to put a nut on it before you cut it shorter so when you cut it you can unscew if and clean up the threads.
tallyram 04.14.2006 07:16 AM
thanks guys, i'll give it a try.
