Pics of your Pede and Rustys please.
I need pictures so I can get some ideas on how I am going to do the electronics and battery mounts on my FLM rusty and pede. I run different sized Lipo packs so I need some way to use the Gorilla battery straps. Please post pics of your pedes and rustys with all of the electronics mounted and battery in place.
Here is what I have so far, but as you can see, I will be starting over with a FLM chassi. Carbon fiber sucks. http://img20.imageshack.us/img20/564...57large3mu.jpg |
This is the only pic I have of my pede at the moment. It too will be getting FLM everything.
http://img467.imageshack.us/img467/5...55large3re.jpg |
My Rustler has:
-Nitro Rustler front spindle/block conversion with aluminum carriers -FLM extended front arms -RPM wide bumper -fiberglass shock tower (cracked the CF one) -Duratrax Overdrive ST shocks with soft springs and 30wt. oil -FLM front bulkhead -custom chassis from 1/4" polycarbonate with aluminum angle pieces for stiffening and battery holding (need to put a brace from upper deck to angle pieces) -Blue Bird BMS-620mg servo -Electric Power 4s 5400mah 8C Lipo battery custom modified to fit the chassis (also use this battery in my 1/8 buggy) -Ofna 1/8 Super Shocks in the rear (VERY nice) -cut up stock shock tower on custom aluminum tower (needs replacing) -FLM aluminum gearbox (I've scraped the crap out of it!) -aluminum idler, steel top gear, stock differential -Feigao 540 12s (loose front enbell) with MGM Compro 12012 and a XUS Hobby UBEC -HPI Yokohoma tires on Traxxas lightweight wheels http://img.photobucket.com/albums/v1...r/IMG_2458.jpg http://img.photobucket.com/albums/v1...r/IMG_2468.jpg http://img.photobucket.com/albums/v1...r/IMG_2465.jpg http://img.photobucket.com/albums/v1...r/IMG_2464.jpg http://img.photobucket.com/albums/v1...r/IMG_2462.jpg |
MetalMan where did you get those aluminum carriers?
The front aluminum carriers are these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXSK19&P=7 They are for the Nitro Rustler, which uses a different wheel setup, where the bearings go into the wheels (like Associated and Losi). I forgot to mention that I am also using aluminum rear axle carriers: http://www2.towerhobbies.com/cgi-bin...?&I=LXMW88&P=7 |
| All times are GMT -4. The time now is 02:21 PM. |
