1717 muggy cog
I am having some cogging issues i think. Sometimes it cogs and others it rolls slow then hit with the throttle.
Setup 1717 heli Mmm 6s 45-50c 5k tenergy pack(2 3s in series) 5.5mm bullets on batteries an 6.5 on motor 50/14 gearing pinion might be a 16 gotta double check Any ideas |
What firmware are you running on the MMM?
I had a similar problem running the Neu 1521 in my XXL. When i was using the newest firmware, it would only roll very slowly unless I gave it a push. I tried all different settings, timing, start power, everything but nothing helped. I changed the firmware and haven't had an issue yet... |
I started on 1.24 i think and now have the latest. Had the same effect on either firmware.
Try 1.21
Thank you 1.21 worked like a charm....now I need to change the center diff fluid to equal out the power front to rear.:yipi:
| All times are GMT -4. The time now is 10:59 PM. |
