-   -   Is it over? (https://www.rc-monster.com/forum/showthread.php?t=28443)
bigboi146 10.30.2010 06:49 PM
Is it over?
Hey guys I was trying to pull a motor wire out of my mamba monster and the receiver wire completely ripped the wire for the receiver out of my esc. I tried soldering it all back together but now it's not working. Should I try to solder it correctly or should i spend the $70 and send it in for repair?
whitrzac 10.30.2010 08:44 PM
so the wire that goes to the reciver riped out of the esc?
it shouldn't be too hard to resolder it:neutral:
I'v never soldered on a MMM, so I'm not sure how tight it is inside the case...
Arct1k 10.30.2010 11:24 PM
Castle only charge $15 IIRC to fix wires
simplechamp 10.31.2010 12:11 AM
You just remove the whole ESC board from the case. It's not an issue of getting in there, just that it can be tough to solder those small wires onto the tiny solder pads without shorting between them with solder or overheating the pads or nearby components.
bigboi146 11.01.2010 04:20 PM
I'm going to have to get on the phone with castle to see whats going on
Arct1k 11.01.2010 05:07 PM
PS Now you've attempted to solder to the board it is $70 if you've damaged the controller unless they take pity on you.
Prior to that it would have been $15 IIRC if the solder pad was still intact.
