BL motor
The new Feigao 380c motors are those "540" size or are they "380" for micro cars? It says 540 bolt pattern but the 380 in the name throws me off
Thank you, Chris P.S. Mike: When it is released will you stock The Mamba Max? If you already have an shipment expected to come in, when is the arrival date? |
The 380C motors are 380 size motors internally, but the exterior gives it the 540 size. Just FYI, the Novak brushless motors are also 380 size on the inside.
The Mamba Maxx is going to be a while still, beta units aren't even out yet. |
So if i got the 6760k/v motor would it be "better" than my Feigao 6s?
How does that work? 380 internally in a 540 can? Thanks metalman, Chris |
It will be better in the sense that it will accelerate faster and will be easier on your batteries (since it doesn't require as many amps).
The heatsink and the front and rear endbells bring it to the 540 size. Without the heatsink, it would be a 380 motor with 540 endbells. |
Would the overall speed be faster? Since it has a higher k/v rating. I am very interested in this motor since it draws less and accelerates faster. If it is faster runs longer and draws less I may soon purchase one for the (commercial type speech)unbelievably low price of $66! lol
Thanks, Chris |
If you have very good batteries, then the 540 6s should be faster, simply because it can handle more power.
| All times are GMT -4. The time now is 10:27 AM. |
