Charging at more than 1c with Duratrax Ice?
Is it safe to bypass the 1c limitation by lying on mah capacity?
Ex: I have 3s 5000 so I can't charge at more than 5 amp. If I set it up as 7500 mah, I can charge at 7.5 amp. Will it peak correctly or not ( And I use a LBA10) Is the mah setting is there as a title or it does somethig at the charge (Peak). Thanks Fred |
The ICE is technically a 1C charger, but like you said, if you set the capacity higher it raises the maximium rate of charge. Assuming the pack can support a higher rate of charge this is fine to do. The pack will not become overcharged, since a LiPo charger will always stop at 4.2 V/cell- just make sure the # of cells is set right (obviously?).
That's what I tought but just want to be sure!
Thanks |
| All times are GMT -4. The time now is 10:34 PM. |
