My E-GST
A long term project, started one year ago.
http://i361.photobucket.com/albums/o...y/DSCN4999.jpg Original center diff, then modified to use two telescopic cdv. http://i361.photobucket.com/albums/o...e/DSCN5325.jpg Modified http://i361.photobucket.com/albums/o...e/DSCN5326.jpg This is the original motor mounts made but a friend of mine, but he did it without thinking too much. A lot of measures were wrong and i've made a lot of work to make it functional. Distance between spur and pinion, holes for the tvp, distance from ground and position of the center diff are wrong. I milled the motor mounts by myself and builded two carbon plates to fit them in the chassis. http://i361.photobucket.com/albums/o...e/DSCN5327.jpg And this after some work to make it usable. http://i361.photobucket.com/albums/o...y/DSCN6350.jpg http://i361.photobucket.com/albums/o...y/DSCN6351.jpg Some studies to fit everything in the small chassis http://i361.photobucket.com/albums/o...y/DSCN6354.jpg http://i361.photobucket.com/albums/o...y/DSCN6352.jpg |
Wow... Nice. The CF plates look fine in there, and they allow you to remove the entire assembly at once for easier service. :yes:
This is my solution form twin steering servos. A must in a monster so huge and heavy. Two bluebird digital with 14 kg/cm inside hobao servo mount.
http://i361.photobucket.com/albums/o...y/DSCN6397.jpg http://i361.photobucket.com/albums/o...y/DSCN6398.jpg General view with medusa 36-80-1600 http://i361.photobucket.com/albums/o...y/DSCN6394.jpg http://i361.photobucket.com/albums/o...y/DSCN6395.jpg |
But with original spur and 11T pinion there was too cogging (another error not calculated by motor mount guy...)
So i switched a 66 spur instead of the original 46... http://i361.photobucket.com/albums/o...y/DSCN6412.jpg http://i361.photobucket.com/albums/o...y/DSCN6413.jpg http://i361.photobucket.com/albums/o...y/DSCN6415.jpg http://i361.photobucket.com/albums/o...y/DSCN6416.jpg The cogging went away but for this Monster the medusa was too tiny so i changed it with a Castle 1717. More more power. http://i361.photobucket.com/albums/o...y/DSCN6447.jpg http://i361.photobucket.com/albums/o...y/DSCN6442.jpg http://i361.photobucket.com/albums/o...y/DSCN6444.jpg http://i361.photobucket.com/albums/o...y/DSCN6443.jpg http://i361.photobucket.com/albums/o...y/DSCN6445.jpg http://i361.photobucket.com/albums/o...y/DSCN6449.jpg |
My final setup is:
MMM esc sealed without fan and without bec. Castle 1717 1580 kv, Lipo 6s Turnigy 5000 mAh, Life 2s 1700 Hyperion for rx and servos, Two digital heavy duty bluebird servos, Futaba 4PK. |
wow, you have almost completly did my exact conversion i just completed. you have better machine work on the mounts than i do, but very close setup. we think exactly alike on how this should be setup. bravo to us both. i will post some picks of mine later.
did you cut down your front shaft? mine is alot tighter than yours is. |
I like the strut/stabilizer setup on the front and rear
so how is this truck pulling its weight with 6s power? mine on the 4500 30c 3s geared for about 30 does flip onto its lid and 1/2 time can do mid speed willies. can you do a flip? thats my goal. also is your diff locked, mine was from the original trans. that might have to change so i don't tear everything up or invest into a slipperintial.
The monster is powerfull but not from 0 or at low speed. Maybe your esc is better in this case. |
Well done. That truck is a monster for sure
| All times are GMT -4. The time now is 09:16 AM. |
