-   -   Looking to buy a small car that's super-quick (https://www.rc-monster.com/forum/showthread.php?t=28596)
ReV:-O 11.17.2010 11:57 AM
Hey guys,
Basically i might be looking to get a small car, something like a 1/16, maybe a 1/12 or something like that. I dont really have a lot of space around here as I'm at uni, so id just be driving it in the street etc, so i dont want anything bigger really.
I need it to be fast cos all i'll probably be doing is full throttle runs, so i'd like to manage at least 65-70 without burning out the motor or something catching fire.
Back home I own a HPI Vorza running the 2650kv motor on 6s, and I've GPS'd that at around 65mph, so I'd like to get at least that.
Any help and advice would be greatly appreciated!
Cheers
magman 11.17.2010 12:09 PM
The 1/16 revo on 3s really flies with street tires
alport 11.17.2010 03:09 PM
1/16 revo vxl is hard to drive at high speeds because of relatively high LCG, but rally vxl may be a good alternative with same chassis and electronics. It's near a 4/5 of an 1/10 onroad car. Electric converted crt.5 is also cosiderable with low LCG and great width.
BrianG 11.17.2010 04:06 PM
I too would be more inclined to use a modified CRT.5 as a base. From what I've seen of the 1/16 Traxxas stuff, the drivelines aren't as robust and you're limited battery-wise to what will fit in those small trays (and they are SMALL).
Bondonutz 11.17.2010 05:04 PM
The Vendetta SC with a dirt oval late model body would be a great canidate.
Easy to work on and the only upgrade needed is CVD's with steel out drives. Put a little 4s pack and decent BL motor and you'll have a awesome handleing robust bullet.
TC tires will work also with vendetta 12mm hubs.
CRT .5 will allow larger electronics and battery packs tho, Will handle speeds better too.
reno911 11.17.2010 05:15 PM
As cool as those new mini drift/rally things Traxxas came out with I would say get a 1/10 tc of a reputable manufacture instead. Fast and reliable. That and with the plethora of aftermarket bodies you will be able to find something with the right aerodynamics to haul balls.
hescobal 11.17.2010 05:16 PM
hyper mini ste 1/16
would a 1/10 truggy be too big? A hyper 10TT is just a slightly bigger version of the hyper mini ste
reno911 11.17.2010 05:26 PM
RCM ten t ftw!
mac3194 11.17.2010 07:47 PM
Rustler vxl??
Dj_Sparky 11.18.2010 03:07 AM
A Corally 12SL 1:12 would be a good choice. These cars can hit incredible speeds and are built to handle it.
el tomaso 11.18.2010 01:54 PM
I ordered myself a Hyper mini STe today, with MMP and neu 1509 3600kv from here. I think it will be good, 3s bashing, 4s speed runs:yipi:
TG
bdebde 11.18.2010 04:11 PM
I have a 1/18th scale M18T with Mamba Micro Pro and Lehner 1020/12 (5000kv) I can let go pretty cheap. May even have a spektrum receiver to go with it... bind and drive! PM if interested.
ReV:-O 11.19.2010 11:19 AM
Thanks for all the advice guys. I'm not really looking for an on-road car since i'll be driving it on uneven terrain. I think that means I'd probably be looking for a 1/10, rather than a 1/16.
What I'm really looking for is just something really cheap, with a really light, simple chassis but that can handle the power. Maybe something like the Ansmann Macnum or Madrat. I know Ansmann arn't a great make but they are cheap, which is what I'm looking for. Theres also others like the Traxxas Rustler/Bandit, Losi Speed-T, Associated RC10B/T4.1, HPI E-Firestorm, and I'm sure there are loads more.
Idealy I'd want to buy a roller so I could stick in my own motor, esc and lipo; that way I could choose the fastest option, like choosing a 4800kv motor and running it on 3s, then upping it to 4s for speed runs. I don't really want to convert a nitro chassis because it will probably work out too expensive.
Also, being waterproof is a fairly important factor for me. I'd like to be able to take it to the beach and not have to worry about it getting wet etc. With my Vorza I have to be careful where I drive it so as not to get the electronics wet.
Just as a side-note, some of the battery compartments such as that of the Rustler/Bandit look extremely small, and I'm not sure if I'd even be able to fit a decent 3s or 4s lipo in there without squashing it to pieces!
reno911 11.19.2010 11:50 AM
Converted Jato maybe. Rollers are fairly cheap.
ReV:-O 11.19.2010 03:05 PM
A few people have told me to go for either a Rustler or a Bandit, but I have a few questions regarding them. They also told me that since the battery tray is so small, I would not be able to run 4s. Also, they said the Traxxas esc wouldn't be able to handle it unless i got an external BEC, and even then it would likely end up in flames.
If I got a Rustler/Bandit, I wouldn't want the 3500kv motor, I'd wanna get something with a higher kv, maybe around 4800kv if I'm only gonna be running 3s.
Traxxas claim it to be waterproof, but how can this be when the motor and lipo are exposed? Are brushless motors waterproof? I know lipo's arn't!
