-   -   FS: MGM 22418 ESC, 5s LiPo, 2.4Ghz Tx/ Rx, Feigao 10XL, Mamba Max, Castle Link (https://www.rc-monster.com/forum/showthread.php?t=28603)
bensf 11.17.2010 10:33 PM
I want this stuff gone. I will give discounts if you buy multiple items.
MGM 22418 SOLD
MGM USB kit. SOLD
Futuba 3PM w/ FAAST Transmitter and Reciever 2.4 GHz
Feigao 10XL, Black model
TrueRC 5s2p 8000mAh pack. A little beat up but works fine.
Mamba Max I haven't used it much, PO's description (jnev), "The separate MM ESC (which I actually received today), has a the switch wire torn off (must have happened during shipping) and has a Novak cap soldered on the the wires that lead to the battery as well. The case also has some holes drilled into it for additional cooling. So other than the switch wires, (which isn't hard to fix, just need to solder them on) it is in perfect condition. The previous owner (entjoles before jnev) also said that it can run 5s no problem ." Connectors and box included included, can't find the instructions though.
Castle link
http://bensukys.smugmug.com/photos/7...08_La9zy-L.jpg
bensf 11.18.2010 02:04 AM
http://bensukys.smugmug.com/photos/7...12_gkXVa-L.jpg
http://bensukys.smugmug.com/photos/9...42_UGFiC-L.jpg
