Savage Flux first impressions
I pulled the trigger and ordered a Savage Flux HP from Tower last Sunday. After having several Maxx trucks, that always broke easily, I decided to try a Savage. From what I have seen on here and HPI's site they really seemed to be built to take some abuse.
Truck showed up yesterday and I've only been able to use it a little. Upon opeing the box and pulling it out I was amazed at the size and weight. This truck is without a doubt a bit bigger and more robust than a E-Maxx. I like that the wheelie bar is included and isn't such a protrusion off the back of the truck that it makes jumping a danger. Having a rollbar under the body reminds me of the nitro revo, it's nice to have that suppurt there rather than the motor mount being the highest point like a E-Revo/Maxx. When dropped from chest hight, even with single shocks, it doesn't bottom out like a Maxx or Revo, at least in the out of box configuration. I do plan on putting my Hitec 7955TG servo in the truck when I get some time, perhaps this weekend, but the single stock servo seems more up to the task than the dual servos from Traxxas. The immediet downfalls I have seen so far are that the slipper needs to be tightened immedietly, the battery boxes need a little bigger cutout for the wires to exit, the straps used to lock the battery boxes are a joke, and the chrome on the wheels comes off easier than on Traxxas wheels. None of those negatives are a big deal, to fix all of them it will take less than 5 minutes and only need to purchase a set of velcro straps to make sure the batteries stay in place. So far I am very pleased with my purchase. I immedietely swapped out the stock radio for a Spektrum rx to use my DX3R and my only other planned upgrades are the servo and probablly a new F series body. Might also get the GT2 tires like Freeze has and a set of black rims. |
You are going to love this truck! Just a few things you might want to do: Get the HD tranny gears, the stockers suck. You will need to buy shims to shim the new tranny gears because they are very narrow, you will see what i mean if you buy them. Also ditch the metal spur and use just a normal plastic one, you will need to buy the bronze bushing from you LHS. The plastic gear is much quieter and will not destroy pinion gears. I have went through 2 RCM pinions on mine before i decided to switch to the plastic spur. Plus the plastic purs are like 3 bucks, where a good quality pinion is around 15-20.
Sorry, I did forget to mention I will be playing with gearing. I didn't get the Flux so I could have a speed machine, stock gearing is to fast for my taste in a MT. When I want speed I know my truggy will outperform the Savage. I plan on gearing down considerably. Stock is 44/20, I will go up a few teeth on the spur and down a few on the pinion
Where do I find these plastic spurs? Only finding steel ones.
Here is a thread that has the spur and the bronze piece listed http://www.rc-monster.com/forum/showthread.php?t=28345 |
Thanks, found them. I'll prolly get the 47 or 49 and get an 18t pinion
And put in that 7955TG!
I also found the first downfall of the Flux, changing pinions is a PITA!!!! |
Back long ago when I had my savage.
They had a single slipper and dual. The dual held much better. I not even sure options on that any more but thought would throw it out there. |
Yeah they made a dual slipper. Kinda like the robinson setup for some of the other nitro MTs.
I second the plastic spurs. Never had an issues with any of my savages. Now that you have graduated from the maxx next step will be to get a lst and convert it. |
I had one. So not mistaking it with a brake.
I put it on a nitro trans with 3 speed gearing. Had one of them small 2250 lehner on it. The single slipper wouldn't handle the pressure. I got a thread around here some where about it. |
Shouldn't be a tough mod to do would it? The tranny has a long shaft, and the motor is adjustable forward and aft.......
It was on the http://www.hpiracing.com/kitinfo/858 which I believe was the original Savage X part #. See page 37 of the manual. Looks like you need parts:
http://www3.towerhobbies.com/cgi-bin...FVSEARCH=86802 http://www3.towerhobbies.com/cgi-bin...FVSEARCH=77094 http://www3.towerhobbies.com/cgi-bin...FVSEARCH=86801 http://www3.towerhobbies.com/cgi-bin...FVSEARCH=87243 http://www3.towerhobbies.com/cgi-bin...FVSEARCH=86800 Doesn't look like there is much choice other than the 49t spur. |
looks like a waste of time really, especially since you would need a special spur gear.
| All times are GMT -4. The time now is 09:56 PM. |
