1717 6mm shaft question
Hello Patrick,
Was wondering if you had any sort of trade in program for those of us who got the 1717 motors with the 6mm shaft? I did "turn" mine down to 5mm but would prefer something factory done... I remember this being mentioned a while back but I cannot find it. Big thanks to the CC team!! |
PM thomas if he has any spare rotors
What is the bolt pattern on these motors?
Pretty sure its standard 25mm spacing, also pretty sure it uses M4 bolts for mounting.
I wouldnt worry about the home-brew 6mm > 5mm shaft, so long as there is no slop in the pinion on the shaft, and the shaft is uniformly 5mm ( not shaped little skittle at a bowling alley )... |
| All times are GMT -4. The time now is 09:35 PM. |
