cc 1520 gearing/lipo ? in flux
I have recently put the cc sale motor to good use in my flux. With a little ingenuity and alot of dremeling i got a clean custom fit. I made my own motor mount which limits gearing to 20t pinion 44t spur or if it i go smaller spur i can fit a bigger pinion vise versa. Also what is the best lipo setup for this motor and mmm esc. I currently run 5s. Any suggestions to run the most optimal setup would be appreciated
4 Attachment(s)
Here are some pics of my build
1 Attachment(s)
Noob ? how do you upload more than 4 pics at a time?
I ran a 1520 on 6s with a 17t pinion and it was/is perfect. I just don't drive it anymore which means I'll probably end up selling it, but it rocks. Good run time out of two Turnigy 5000mah 3s 35c packs in series, good temps, alot of fun.
How is that a good setup?
A 1520 1600kv motor with a 17t pinion and 44t spur and stock flux tranny on 6s is only geared for 33mph or so??? That is extremely undergeared, and terrible top speed??? Even with a 20t pinion you are only geared for 39mph... and from my findinigs is that what ever the speed calculator results in, you should take off 10mph for actual speed.... I am geared for 53mph and i hit 43mph actual speed. When running my 1520 with flux tranny... i ran the 39t high speed idler and ran an 18 t-19t pinion for around a 50-55mph calculated top speed so more like 40-45mph and i ran extremely kl temperatures... When geared for around 40mph my motor temps were very hot and my esc and lipos were extremely cool. |
I'm running 6s with the 39t idler. With the 44t spur and a 20t pinion I'm getting 52mph on my radar. This is with Proline Badlands on JConcepts Rulux. Lipos cool, ESC cool, and the 1520 just warm to the touch. I have limited space too. I might jump to the 43t spur and try to fit a 22t pinion in there.
DAMN Your getting 52 mph out of the badlands. Aren't they made for offroad. I think im going to give them a try. I've always looked for and offroad tire that could do descent speeds without losing control. I guess coming from the stockers is almost always an improvement. Is there anyone that might make a spur gear that will fit the flux that is lower than 43 t
Guess I don't know what I'm talking about though, I'll keep my setups to myself....thank you and goodnight. |
Thats the way I mounted my servo in my savage. Is that very common? IDK
But i just wanted to highlight that such an undergeared setup would cause your motor to over heat. As i mentioned, my motor was reaching high temperatures when i geared my 1520 for 35mph (i wanted to see what the torque would be like) after a few temp recordings... my ESC and lipos were still COLD and the motor was hitting 70degrees... i then put the gearing back to 53mph and my temps remained warm across the 3... But MY GOD when i had the savage geared for 35mph with the 1520... there was so much torque that i did at one point do a standing DOUBLE backflip after warming my tyres up for max traction!!!! (it was a bit of a fluke, but it still happend!) |
I appreciate everyones post and input. Brian,I did not specify any specific goal other than to post what worked for everyone so i could get an idea of where to start. It is really unecessary to take anything personally on this forum as it is impossible to tell the mood of "text" in a conversation. As far as the servo mount, im not sure if it is the norm but it replaces the big and bulky box really made for the nitro savage and it is alot easier to work on with it mounted this way. I ran my new setup twice and if feels alright but i think 20t/44t is a little much for this motor as torque was lacking a little on 5s(believe it or not)?
I forgot to mention where i live now its around 30 degrees so it allows for more cooling than normal so i guess i should take that into account I havent tried 6s yet either. That may be the problem as this motor is rated for 8s?
| All times are GMT -4. The time now is 09:36 AM. |
