Installed external antenna on React
Some of you know that my Star Trek phaser gun Nomadio only has an internal antenna. I wanted some more range with the Telemetry, so installed an external antenna. Worked better than expected and doubled the range.
http://i189.photobucket.com/albums/z...p/PB110001.jpg |
Very nice, did you just use an aerial? or any amplifier?
Yea, just the antenna which I got from work. I had to unsolder the plug and solder on the new one.
The telemetry range double. I think the regular radio range is still the same as no amplifier is used. |
Good solution!
I did this also on my 4PK. I installed a d-link antenna with more gain than the original. When i turn on the radio the signal stop all the wifi around my house AHAHAH. http://i361.photobucket.com/albums/o...y/DSCN5247.jpg |
Anyone know if my Nomadio Sensor could benefit from an antenna upgrade? Am I looking at the dBi values they all seem to be rated with? Or would you need an actual amplifier along with the antenna? I don't have any range issues with the stock antenna, but a little more range couldn't hurt.
You might gain a bit. I went up the he network guys at work and asked them for an antenna that would help me gain some range with my telemetry. They gave me a antenna that is being used on the new commericial stuff and told me I should see some increase with just the antenna. The React just has a wire as antenna, so no gains build in. I have another set of wire and antenna if you would like to try it out.
| All times are GMT -4. The time now is 12:58 PM. |
