-   -   what do i put in my e maxx diff??? (https://www.rc-monster.com/forum/showthread.php?t=28778)
rcbeast 12.10.2010 10:06 PM
i recently stripped my rear e maxx diff and i am replacing the ring and pinion gear and i am wondering what i am supposed to use to lube the gears... can i just use some regular greese? all info help
thanks,
rcbeast
What's_nitro? 12.10.2010 10:35 PM
Yes, you could use regular automotive grease. You can also try Gorilla Snawt- It's really sticky so it stays on the gears, but also really slippery so it actually reduces friction a lot.
rcbeast 12.10.2010 11:00 PM
thanks for the info man
rcbeast 12.12.2010 05:07 PM
ok so i bought a new ring gear and it comes with the black little housing (sorry i dont know the correct term) it is where these go http://www.buytraxxas.com/product_in...oducts_id=2922 and im going to swith my gears out to the new "housing" and was wondering what i need to use to lube this area can i just use grease like i would use for the ring and pinion gear?? all info helps thanks...
E-Revonut 12.12.2010 05:45 PM
That would be the diff cup. Generally you would put a silicone differential oil in there, there are different viscosities to give you different amounts of diff action, thicker oil will act more like a locked rear end. If you don't want to bother or don't want to wait you can put some grease in there to keep it lubed.
rcbeast 12.12.2010 05:55 PM
thanks for the info... what weight would grease be close too? and how close would it be to a locked diff?
