Savage Arms Difference
Could some one tell me what the actual difference is between Part FLM41510 xl arms and the 41500 arms for reg?
Both say .5 wider and such. Is one wider then the other or different mounting? |
I believe the XL kit is for the thicker dogbones found on the flux and XL line of savages. Ie for 11mm cups instead of 8mm iirc
So both would be same length over all?
Interesting indeed. Just thinking about a Savage beast to build. |
So the Flux or XL is heavier duty usage?
| All times are GMT -4. The time now is 12:54 AM. |
