rustler front lower arms
does any one know if the nitro rustler lower arms will work on the electric rulster....
im converting my rustler/stampede to all aluminum FLM/GPM products.... unfortunately i cannot seem to find the GPM front lower arms ANYWHERE!!!! but i CAN find the nitro rustler set.... all else i need is the blue slipper plates, blue turnbuckles, and waiting on my RC-MONSTER aluminum diff gear.... then ill be mostly complete, just gotta save the money for the motor and ESC. |
i would go for the flm parts. the gpm are ok for some stuff but most of it, parts like a-arms, are a no-no. they arent very high quality. i would go for the flm extended arm conversion, but to answer your question, they will work, but you need longer turnbuckles.
If you cant find the parts any where than ask Mike, he can get you just about anything for your truck(s)!
well, i've already got the GPM rear arms, C-hubs and knuckles, to have the FLM sliver and GPM blue mix, so thats the only reason i was trying to find them, to keep the silver/blue theme going........ everything else is all FLM... although i was considering getting the FLM extended arms if FLM can anodize them for me....... but would i need to get extended turnbuckles for that?
who's mike? |
Mike is the owner of the rc-monster store, just send him an email, sorry for not telling you, i was sure that you knew who he was!
not yet, im still fairly new here and to the RC hobby all together
Sorry, ill try to explain my self better with any questions you have. -just so you know, If you ever order anything from Mike, you will be amazed on how fast he ships and how happy you will be, you will fit in nicely with the rest of us here:)
awsome......... thanks sylvester
I used to use the RPM LXT arms, which were extended plastic arms. Now, I use the FLM extended front arms on my Rustler, and they hold up very well. Nitro Rustler front arms work on the front (I used to use them), but they are narrow. Go for the FLM, and you can't go wrong!
| All times are GMT -4. The time now is 12:34 AM. |
