Internal antenna mount
Hello all how do I make an internal antenna for a Stamped?
I am not sure what you mean by an internal antenna.
internal antenna.
a antenna under the truck body,not outside it.
My solution was to get a Spektrum system. It's got a short antenna. :)
I've heard of some people putting a lexan plate between the front shock towers, then putting holes in the lexan and threading the antenna through them. |
The spektrum is nice:) But for the stock id just either use one of the ones on the site shown (above) or just look at the truck and "think" until you pop out an idea.
Thanks, I'm a new guy to all of this so I wraped the antenna wire around the body mounts and used ductape and guess what?..It works great,range over 100 yards!!!!!Using 3300 bats.It really smoakesssss. I'm hooked on R/C
Good to hear you found a spot. Just make sure to check if and when you have cuts in the wire, the body posts arent the best place but should do for now!
| All times are GMT -4. The time now is 08:26 AM. |
