New CC 2028 seems to be out.
http://www.castlecreations.com/products/2028_motor.html
"This motor can easily run in the 10 horsepower range." Quite a statement. This means that it can atleast produce 8000-10.000 watt? |
Yup, it's out. I wouldn't doubt their claims, it's heavy and BIG.
http://i1176.photobucket.com/albums/...224_120417.jpg I posted more pictures in the Castle 5th scale thread. |
Is it only possible to order it from the CC site at the moment? Would like to order somewhere faster..
Correct me if I'm wrong, but isn't that identical to the Neu 2230? Same size and weight? I will be ordering one tomorrow most likely, and run it on 6s til I can afford the Mamba XL. Will it run nicely on 6s? Or should I just wait til I get the Mamba XL? (Won't be that long.) |
I ordered from the CC site and through correspondence via E-Mail, got my motor and ESC today and it was shipped yesterday (which was the first batch of shipments I believe). I don't think anywhere else you buy from will be any faster, if you can even find another place right now.
Ah, will just order from CC then. Will maybe get the ESC too. But could you tell me if the 2028 is identical to the 2230 or not?
It's not. Is is redesigned by Castle for better Car use I think. I think it puts out the same amount of power as it seems to be VERY similar, just a different case for the most part I believe.
Castle uses the same labelling/ name system for their motors as Neu, so logic dictates that the castle 2028 is gonna be noticeably smaller than the 2230 I'd have thought:
2028 = 2.20" diameter & 4.4" long 2230 = 2.50" diameter & 4.7" long Didnt take me long to find that info out by comparing the listed specs on the castle website of the neu & neucastle motors... http://www.castlecreations.com/produ...rs/nm2200.html http://www.castlecreations.com/products/2028_motor.html |
And both motors fit info my Baja5b Brushless conversion kit :)
That is nice. Will have to order one. Dejan |
Was thinking of putting it in a GST 7.7 until I get a 5th scaler.
Highest spike I had was 7hp
| All times are GMT -4. The time now is 01:10 AM. |
