Setup?
I just bought a Stamped,what would be the best setup for it to run on grass&hills? Thanks
How much are you willing to spend?
and of course, the age old question, how many cells? but as for escs i would go for the mtronics truck controller.
The Mtroniks Genesis Pro controller should be enough. It's pretty much the cheapest you can get besides the Warrior 7020, and it's a much better controller. A motor recommendation depends on your budget, and like squee said, the number of cells you will run.
mtroniks will do good for you and welcome to the forums
| All times are GMT -4. The time now is 05:05 AM. |
