-   -   ntc3 conversions (https://www.rc-monster.com/forum/showthread.php?t=28881)
junkman 12.26.2010 02:32 PM
ntc3 conversions
Just aquired a couple nice nitro tc3 rollers for cheap. Searched through some old threads to get some ideas, but looking to see if anyone has put one together recently what route they went with for a mount. I would like to have something maybe a little nicer than the standard ol l-bracket mount. Probably use a twin force batt tray. Thanks ahead for the help.
Semi Pro 12.26.2010 11:16 PM
just use mikes revo mount thats the cleanest way to mount the motor
junkman 12.27.2010 02:51 AM
I've seen a few jato's converted using the revo mount, does make for a pretty clean setup. I found these pics, but the thread is couple years old, and the poster hasn't been logged in for over a year. Looks like something made for the application.
http://i239.photobucket.com/albums/f...ifter/NTC2.jpgtopic=12775&hl=ntc3
http://i239.photobucket.com/albums/f...ifter/NTC8.jpg
http://i239.photobucket.com/albums/f.../Entc3trio.jpg
http://i239.photobucket.com/albums/f...r/PICT0022.jpg
simplechamp 12.27.2010 06:06 AM
I don't think those motor mounts are made specifically for converting the NTC3. Most of those look like the person used motor mounts from some other electric TC's and drilled the chassis out to make mounting holes for them. Shouldn't be too difficult to do, just need to figure out which motor mount will be a good fit.
Here are a few examples, not sure if they will actually work, but you get the idea:
http://www.amainhobbies.com/product_...ho-Motor-Mount
http://www.amainhobbies.com/product_...es-Motor-Mount
http://www.amainhobbies.com/product_...ic-Motor-Mount
You could also look into using the RC-Monster Revo mount as mentioned, or one of the Tekno motor mounts like this:
http://www.amainhobbies.com/product_...a-Novak-Motors
For a battery tray the RC-Monster CRT.5 tray is a good fit for most standard 2S hardcase packs. I am using one in my Diggity Designs XLR8 electric TC3.
Semi Pro 12.27.2010 02:28 PM
the mounts are from the alex racing baracuda, i have one, so is the sparklie top plate lol
Bosox06 01.05.2011 09:58 PM
Also looking for a clean mount for a nitro tc3
junkman 01.06.2011 01:33 AM
I think this would be a pretty much bolt in clean mount
http://www.xtremercracing.com/Store_...ue&SnipID=3042
I was needing to order some stuff from ae anyway so I picked up a couple of these to try
http://order.aeteam.net/product_deta...?Itemcode=4537
my thinking is the rc0l has several bearing height adjustments that snap in the oval hole. Maybe one will aline the bearing up with the center shaft properly.
