This forum my last hope?
Greetings, one and all,
I'm posting here because the folks seem genuinely helpful. I need a pinion gear. It's not for a truck but a Maxon coreless motor to go in a big German train I have. I've done a lot of research, but haven't found a match. I'm hoping that someone here might tell me how to proceed. Here's the info about the needed gear: 10 tooth 2 mm bore 7 mm outside diameter (might have once been 7.5- it's now worn.) 5 mm inside diameter (base of teeth) 5 mm length Detailed picture at: http://www.flickr.com/photos/28638959@N08/5303819296/ Thanks, Tom Cox PS: I have looked at dozens of vendor sites and found close matches. But I just don't know how to proceed. I know that it's a very dicey thing to try to replace a pinion and get good mesh. But I want to try. The engine has nostalgic value to me. Train forum folks haven't been able to help. |
we are and here you go
https://sdp-si.com/eStore/ i would need to know alot more about thr pinion you need to find you the right one, but if it can be found it will be at sdp-si |
10T @ 7mm diameter = 43.54p (Mod 0.58). Calculated from http://scriptasylum.com/rc_speed/gear_calc.html
Not much help, but you can get an idea... |
sdp-si are very good. I have seen all kinds of gears there. Give them a call or send them an email and I am sure they will be able to help.
I may have made a big mistake by trying to gently remove the burrs with a dremel. It meshed a bit better. But it's still not right. And I'm just at a loss on what to do next. Should I buy several gears that are close to this one and hope for the best? I can furnish pictures of the pinion, pictures of the spur gear it meshes with, measurements, whatever is needed. I appreciate very much your help, believe me. Thanks, Tom |
Again, many thanks, Tom |
Regards, Tom |
Brian's website shows that if the gear was originally 7.2 mm then the pitch would be mod 0.6. That's 48 pitch isn't it? I think that might be it.
Maybe look in the slot cars area? http://www.ncphobbies.com/arp-1/24-g.../arp4810strts/ Or could this fit? http://store.rc4wd.com/10-Tooth-48-P...ear_p_597.html Or maybe find something on ebay? http://cgi.ebay.com/Losi-Night-Crawl...item20b6214e1b |
Scan and fax exact size copy
I also have taken a great many photos and measurements. Thank you, Tom |
It might also help if you had dimensions for the gear this pinion meshes with, if it is not too worn.
I would try a 48 pitch gear, there are 2 types of these, if memory serves me correctly. tamiya use a gear that is very close to 48p in most of their tourinc car line. It is slightly tighter pitch than regular american 48p. Not 2mm bore, but 2.3 (1/8").
| All times are GMT -4. The time now is 06:28 PM. |
