-   -   losi 8ight 2.0 buggy conversion (https://www.rc-monster.com/forum/showthread.php?t=28941)
Bloody 01.03.2011 05:57 AM
Hi there, i wanted to know something.
i bought a losi 8ight buggy 2.0 and i'm convertiong it to MMM V3 brushless, i have 48T spur and i wondering what pinion gear i should put on it?
thanks alot.
idan.
jas21373 01.03.2011 09:11 AM
what kv motor you planning on using????are you racing or bashing??????what batteries you usings?????4s..5s....etc
Bloody 01.06.2011 04:07 AM
1. i have MMM V3 2200KV
2. racing and bashing (more bashing)
3. i have 2 of 6s 5000MAH 35-70C (3+3) and i have 2 4s 5500MAH 30-60C (2+2).
idan.
jas21373 01.06.2011 09:21 AM
with the 4s set-up ,15tooth pinion ,13t or 14t pinion for the 6s ,would be keeping an eye on the temps for both set-ups .
for racing i found the 2200kv is way to much for the buggy.
I run a 1512 Neu 2050kv on 4s ,geared 16/45 in my 8ight 2.0 buggy
Bloody 01.11.2011 07:54 PM
are you using a steel spur or plastic?
if you have gear ratio 16/45 on Neu 2050kv so what will give me 14/48 on 2200kv?
(mph, 4s, 6s ect...)
idan.
simplechamp 01.11.2011 08:04 PM
http://www.scriptasylum.com/rc_speed/top_speed.html
Play around with some of the calcs (I use top speed estimator and parameter solver mostly) and you can find out everything you want to know. Shoot for 40mph as a starting point.
